Time Before: 0.02223 seconds
Time After: 0.02860 seconds
Time Taken: 0.00636 seconds
Time Before: 0.02873 seconds
Time After: 0.02920 seconds
Time Before: 0.02942 seconds
Time After: 0.02956 seconds
Time Before: 0.03037 seconds
Time After: 0.03318 seconds
Time Taken: 0.00281 seconds
Time Before: 0.02961 seconds
Time After: 0.03741 seconds
Time Taken: 0.00780 seconds
Time Before: 0.04312 seconds
Time After: 0.04357 seconds
Time Before: 0.04720 seconds
Time After: 0.04842 seconds
Time Before: 0.04238 seconds
Time After: 0.04874 seconds
Time Before: 0.09266 seconds
Time After: 0.09281 seconds
Time Before: 0.10714 seconds
Time After: 0.10839 seconds
End call of global.php: 0.11036801338196
Time Before: 0.11746 seconds
Time After: 0.11762 seconds
Time Before: 0.12008 seconds
Time After: 0.12152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=34611'
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.13851 seconds
Time After: 0.13882 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.13751411437988 seconds with 9 queries, spending 0.0083892345428467 doing MySQL queries and 0.12912487983704 doing PHP things.
