Time Before: 0.01623 seconds
Time After: 0.02088 seconds
Time Taken: 0.00465 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.02099 seconds
Time After: 0.02154 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.02208 seconds
Time After: 0.02228 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.02307 seconds
Time After: 0.02524 seconds
Time Taken: 0.00218 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.02234 seconds
Time After: 0.02974 seconds
Time Taken: 0.00740 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.03673 seconds
Time After: 0.03713 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.03947 seconds
Time After: 0.04068 seconds
Memory Before: 2,770.078 KB
Memory After: 2,769.938 KB
Time Before: 0.03585 seconds
Time After: 0.04089 seconds
Time Taken: 0.00505 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.297 KB
Memory Used: 133.125 KB
Time Before: 0.06544 seconds
Time After: 0.06570 seconds
Memory Before: 3,436.438 KB
Memory After: 3,436.953 KB
Time Before: 0.07705 seconds
Time After: 0.07830 seconds
Memory Before: 3,524.234 KB
Memory After: 3,524.828 KB
Time Before: 0.08909 seconds
Time After: 0.08926 seconds
Memory Before: 4,162.117 KB
Memory After: 4,162.547 KB
Time Before: 0.09191 seconds
Time After: 0.09336 seconds
Memory Before: 4,443.680 KB
Memory After: 4,445.367 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=34666' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.11141 seconds
Time After: 0.11167 seconds
Memory Before: 4,921.695 KB
Memory After: 4,921.938 KB
