Time Before: 0.01671 seconds
Time After: 0.02242 seconds
Time Taken: 0.00571 seconds
Time Before: 0.02254 seconds
Time After: 0.02300 seconds
Time Before: 0.02327 seconds
Time After: 0.02339 seconds
Time Before: 0.02413 seconds
Time After: 0.02610 seconds
Time Taken: 0.00197 seconds
Time Before: 0.02346 seconds
Time After: 0.03001 seconds
Time Taken: 0.00655 seconds
Time Before: 0.03466 seconds
Time After: 0.03511 seconds
Time Before: 0.03784 seconds
Time After: 0.04061 seconds
Time Taken: 0.00277 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03406 seconds
Time After: 0.04086 seconds
Time Taken: 0.00680 seconds
Memory After: 2,261.719 KB
Time Before: 0.07357 seconds
Time After: 0.07375 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.08871 seconds
Time After: 0.08995 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.09723 seconds
Time After: 0.09740 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.09972 seconds
Time After: 0.10119 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=3469' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.12061 seconds
Time After: 0.12095 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.469 KB
Memory Used: 0.250 KB
