Time Before: 0.02192 seconds
Time After: 0.03177 seconds
Time Taken: 0.00984 seconds
Time Before: 0.03188 seconds
Time After: 0.03239 seconds
Time Before: 0.03267 seconds
Time After: 0.03281 seconds
Time Before: 0.03374 seconds
Time After: 0.03578 seconds
Time Taken: 0.00204 seconds
Time Before: 0.03290 seconds
Time After: 0.04080 seconds
Time Taken: 0.00791 seconds
Time Before: 0.05232 seconds
Time After: 0.05270 seconds
Time Before: 0.05498 seconds
Time After: 0.05626 seconds
Time Before: 0.05151 seconds
Time After: 0.05652 seconds
Time Taken: 0.00500 seconds
Time Before: 0.08704 seconds
Time After: 0.08722 seconds
Time Before: 0.11004 seconds
Time After: 0.11132 seconds
Time Before: 0.12135 seconds
Time After: 0.12153 seconds
Time Before: 0.12410 seconds
Time After: 0.12563 seconds
Time Taken: 0.00153 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=34729' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.14563 seconds
Time After: 0.14593 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
