Time Before: 0.00891 seconds
Time After: 0.01139 seconds
Time Taken: 0.00247 seconds
Time Before: 0.01147 seconds
Time After: 0.01180 seconds
Time Before: 0.01199 seconds
Time After: 0.01212 seconds
Time Before: 0.01293 seconds
Time After: 0.01546 seconds
Time Taken: 0.00253 seconds
Time Before: 0.01218 seconds
Time After: 0.02080 seconds
Time Taken: 0.00863 seconds
Time Before: 0.02655 seconds
Time After: 0.02687 seconds
Time Before: 0.02891 seconds
Time After: 0.03034 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02591 seconds
Time After: 0.03061 seconds
Time Taken: 0.00470 seconds
Memory After: 2,261.719 KB
Time Before: 0.04556 seconds
Time After: 0.04573 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.25460 seconds
Time After: 0.25591 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.25835108757019
Time Before: 0.26428 seconds
Time After: 0.26469 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.26728 seconds
Time After: 0.26875 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=34758', badlocation = 1
Time Before: 0.28768 seconds
Time After: 0.28800 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.28659915924072 seconds with 9 queries, spending 0.0084130764007568 doing MySQL queries and 0.27818608283997 doing PHP things.
