Time Before: 0.01494 seconds
Time After: 0.02185 seconds
Time Taken: 0.00691 seconds
Time Before: 0.02194 seconds
Time After: 0.02286 seconds
Time Taken: 0.00091 seconds
Time Before: 0.02323 seconds
Time After: 0.02338 seconds
Time Before: 0.02440 seconds
Time After: 0.02667 seconds
Time Taken: 0.00227 seconds
Time Before: 0.02347 seconds
Time After: 0.03085 seconds
Time Taken: 0.00738 seconds
Time Before: 0.03843 seconds
Time After: 0.03884 seconds
Time Before: 0.04139 seconds
Time After: 0.04268 seconds
Time Before: 0.03772 seconds
Time After: 0.04294 seconds
Time Taken: 0.00522 seconds
Memory After: 2,885.219 KB
Memory Used: 132.898 KB
Time Before: 0.07225 seconds
Time After: 0.07245 seconds
Memory Before: 3,438.320 KB
Memory After: 3,438.836 KB
Time Before: 0.08945 seconds
Time After: 0.09074 seconds
Memory Before: 3,526.016 KB
Memory After: 3,526.609 KB
Time Before: 0.09929 seconds
Time After: 0.09952 seconds
Memory Before: 4,163.914 KB
Memory After: 4,164.344 KB
Time Before: 0.10232 seconds
Time After: 0.10379 seconds
Memory Before: 4,445.453 KB
Memory After: 4,447.141 KB
UPDATE session SET lastactivity = 1783004909, location = '/forums/private.php?do=newpm&explain=1&u=34858' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.12219 seconds
Time After: 0.12249 seconds
Memory Before: 4,911.148 KB
Memory After: 4,911.375 KB
