Time Before: 0.00136 seconds
Time After: 0.00178 seconds
Time Before: 0.00185 seconds
Time After: 0.00229 seconds
Time Before: 0.00253 seconds
Time After: 0.00266 seconds
Time Before: 0.00361 seconds
Time After: 0.00623 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00273 seconds
Time After: 0.01085 seconds
Time Taken: 0.00812 seconds
Time Before: 0.01286 seconds
Time After: 0.01308 seconds
Time Before: 0.01617 seconds
Time After: 0.01738 seconds
Time Before: 0.01217 seconds
Time After: 0.01765 seconds
Time Taken: 0.00548 seconds
Time Before: 0.02415 seconds
Time After: 0.02436 seconds
Time Before: 0.02629 seconds
Time After: 0.02774 seconds
End call of global.php: 0.029527187347412
Time Before: 0.03090 seconds
Time After: 0.03103 seconds
Time Before: 0.03311 seconds
Time After: 0.03455 seconds
SET lastactivity = 1785352683, location = '/forums/private.php?do=newpm&explain=1&u=34913', badlocation = 1
Time Before: 0.04957 seconds
Time After: 0.04988 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.048281192779541 seconds with 9 queries, spending 0.0081677436828613 doing MySQL queries and 0.04011344909668 doing PHP things.
