Time Before: 0.01461 seconds
Time After: 0.02110 seconds
Time Taken: 0.00649 seconds
Time Before: 0.02119 seconds
Time After: 0.02353 seconds
Time Taken: 0.00234 seconds
Time Before: 0.02379 seconds
Time After: 0.02391 seconds
Time Before: 0.02472 seconds
Time After: 0.02706 seconds
Time Before: 0.02397 seconds
Time After: 0.03126 seconds
Time Taken: 0.00729 seconds
Time Before: 0.04033 seconds
Time After: 0.04075 seconds
Time Before: 0.04419 seconds
Time After: 0.04539 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03955 seconds
Time After: 0.04563 seconds
Time Taken: 0.00608 seconds
Memory After: 2,261.719 KB
Time Before: 0.06891 seconds
Time After: 0.06906 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.09077 seconds
Time After: 0.09206 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.094249963760376
Time Before: 0.10381 seconds
Time After: 0.10399 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.10635 seconds
Time After: 0.10780 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=34982', badlocation = 1
Time Before: 0.12571 seconds
Time After: 0.12595 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.12472701072693 seconds with 9 queries, spending 0.0097148418426514 doing MySQL queries and 0.11501216888428 doing PHP things.
