Time Before: 0.00822 seconds
Time After: 0.01038 seconds
Time Taken: 0.00216 seconds
Time Before: 0.01047 seconds
Time After: 0.01111 seconds
Time Taken: 0.00064 seconds
Time Before: 0.01147 seconds
Time After: 0.01166 seconds
Time Before: 0.01256 seconds
Time After: 0.01500 seconds
Time Taken: 0.00244 seconds
Time Before: 0.01174 seconds
Time After: 0.02022 seconds
Time Taken: 0.00848 seconds
Time Before: 0.02467 seconds
Time After: 0.02506 seconds
Time Before: 0.02755 seconds
Time After: 0.02883 seconds
Time Before: 0.02403 seconds
Time After: 0.02908 seconds
Time Taken: 0.00505 seconds
Time Before: 0.04854 seconds
Time After: 0.04873 seconds
Time Before: 0.05553 seconds
Time After: 0.05682 seconds
End call of global.php: 0.058994770050049
Time Before: 0.06162 seconds
Time After: 0.06181 seconds
Time Before: 0.06433 seconds
Time After: 0.06581 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=35020', badlocation = 1
Time Before: 0.08007 seconds
Time After: 0.08040 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.079172849655151 seconds with 9 queries, spending 0.0084331035614014 doing MySQL queries and 0.07073974609375 doing PHP things.
