Time Before: 0.01755 seconds
Time After: 0.02413 seconds
Time Taken: 0.00658 seconds
Time Before: 0.02422 seconds
Time After: 0.02473 seconds
Time Before: 0.02497 seconds
Time After: 0.02511 seconds
Time Before: 0.02586 seconds
Time After: 0.02837 seconds
Time Taken: 0.00252 seconds
Time Before: 0.02517 seconds
Time After: 0.03231 seconds
Time Taken: 0.00714 seconds
Time Before: 0.04201 seconds
Time After: 0.04243 seconds
Time Before: 0.04506 seconds
Time After: 0.04630 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04127 seconds
Time After: 0.04649 seconds
Time Taken: 0.00522 seconds
Memory After: 2,261.719 KB
Time Before: 0.07410 seconds
Time After: 0.07425 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.09248 seconds
Time After: 0.09372 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.10630 seconds
Time After: 0.10649 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.10987 seconds
Time After: 0.11239 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=35191', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.13204 seconds
Time After: 0.13228 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
