Time Before: 0.01794 seconds
Time After: 0.02523 seconds
Time Taken: 0.00729 seconds
Time Before: 0.02531 seconds
Time After: 0.02592 seconds
Time Taken: 0.00061 seconds
Time Before: 0.02617 seconds
Time After: 0.02632 seconds
Time Before: 0.02708 seconds
Time After: 0.02954 seconds
Time Taken: 0.00246 seconds
Time Before: 0.02637 seconds
Time After: 0.03366 seconds
Time Before: 0.04275 seconds
Time After: 0.04312 seconds
Time Before: 0.04559 seconds
Time After: 0.04678 seconds
Time Before: 0.04201 seconds
Time After: 0.04700 seconds
Time Taken: 0.00499 seconds
Time Before: 0.07434 seconds
Time After: 0.07446 seconds
Time Before: 0.09345 seconds
Time After: 0.09471 seconds
Time Before: 0.10552 seconds
Time After: 0.10568 seconds
Time Before: 0.10829 seconds
Time After: 0.10974 seconds
UPDATE session SET lastactivity = 1785359911, location = '/forums/private.php?do=newpm&explain=1&u=35294' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12986 seconds
Time After: 0.13014 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
