Time Before: 0.01844 seconds
Time After: 0.02322 seconds
Time Taken: 0.00479 seconds
Time Before: 0.02331 seconds
Time After: 0.02375 seconds
Time Before: 0.02396 seconds
Time After: 0.02411 seconds
Time Before: 0.02490 seconds
Time After: 0.02732 seconds
Time Taken: 0.00242 seconds
Time Before: 0.02418 seconds
Time After: 0.03199 seconds
Time Taken: 0.00781 seconds
Time Before: 0.04087 seconds
Time After: 0.04137 seconds
Time Before: 0.04395 seconds
Time After: 0.04518 seconds
Time Before: 0.04010 seconds
Time After: 0.04546 seconds
Time Taken: 0.00536 seconds
Time Before: 0.08011 seconds
Time After: 0.08026 seconds
Time Before: 0.10015 seconds
Time After: 0.10157 seconds
Time Before: 0.10700 seconds
Time After: 0.10714 seconds
Time Before: 0.10957 seconds
Time After: 0.11108 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1788850356, location = '/forums/private.php?do=newpm&explain=1&u=35450' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.12942 seconds
Time After: 0.12978 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
