Time Before: 0.00194 seconds
Time After: 0.00261 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00272 seconds
Time After: 0.00318 seconds
Time Before: 0.00348 seconds
Time After: 0.00361 seconds
Time Before: 0.00452 seconds
Time After: 0.00661 seconds
Time Taken: 0.00209 seconds
Time Before: 0.00368 seconds
Time After: 0.01115 seconds
Time Taken: 0.00747 seconds
Time Before: 0.01286 seconds
Time After: 0.01325 seconds
Time Before: 0.01640 seconds
Time After: 0.01804 seconds
Time Taken: 0.00164 seconds
Time Before: 0.01225 seconds
Time After: 0.01822 seconds
Time Taken: 0.00596 seconds
Time Before: 0.02393 seconds
Time After: 0.02407 seconds
Time Before: 0.02659 seconds
Time After: 0.02779 seconds
Time Before: 0.03071 seconds
Time After: 0.03087 seconds
Time Before: 0.03364 seconds
Time After: 0.03507 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=35493', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.04840 seconds
Time After: 0.04871 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
