Time Before: 0.00132 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00239 seconds
Time Before: 0.00262 seconds
Time After: 0.00275 seconds
Time Before: 0.00353 seconds
Time After: 0.00643 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00283 seconds
Time After: 0.01014 seconds
Time Taken: 0.00731 seconds
Time Before: 0.01213 seconds
Time After: 0.01256 seconds
Time Before: 0.01401 seconds
Time After: 0.01526 seconds
Time Before: 0.01145 seconds
Time After: 0.01551 seconds
Time Taken: 0.00406 seconds
Time Before: 0.02084 seconds
Time After: 0.02106 seconds
Time Before: 0.02348 seconds
Time After: 0.02473 seconds
End call of global.php: 0.026588916778564
Time Before: 0.02814 seconds
Time After: 0.02835 seconds
Time Before: 0.03066 seconds
Time After: 0.03209 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=35495'
Time Before: 0.04614 seconds
Time After: 0.04659 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.044875860214233 seconds with 9 queries, spending 0.0087647438049316 doing MySQL queries and 0.036111116409302 doing PHP things.
