Time Before: 0.00135 seconds
Time After: 0.00186 seconds
Time Before: 0.00193 seconds
Time After: 0.00244 seconds
Time Before: 0.00268 seconds
Time After: 0.00282 seconds
Time Before: 0.00378 seconds
Time After: 0.00626 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00291 seconds
Time After: 0.00997 seconds
Time Taken: 0.00707 seconds
Time Before: 0.01188 seconds
Time After: 0.01226 seconds
Time Before: 0.01503 seconds
Time After: 0.01621 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01130 seconds
Time After: 0.01639 seconds
Time Taken: 0.00509 seconds
Time Before: 0.02267 seconds
Time After: 0.02285 seconds
Time Before: 0.02519 seconds
Time After: 0.02647 seconds
Time Before: 0.03065 seconds
Time After: 0.03084 seconds
Time Before: 0.03314 seconds
Time After: 0.03460 seconds
UPDATE session SET lastactivity = 1788957987, location = '/forums/private.php?do=newpm&explain=1&u=35598' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04733 seconds
Time After: 0.04761 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
