Time Before: 0.02113 seconds
Time After: 0.02694 seconds
Time Taken: 0.00580 seconds
Time Before: 0.02703 seconds
Time After: 0.02742 seconds
Time Before: 0.02767 seconds
Time After: 0.02780 seconds
Time Before: 0.02860 seconds
Time After: 0.03196 seconds
Time Taken: 0.00335 seconds
Time Before: 0.02787 seconds
Time After: 0.03625 seconds
Time Taken: 0.00838 seconds
Time Before: 0.04552 seconds
Time After: 0.04573 seconds
Time Before: 0.04923 seconds
Time After: 0.05066 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04484 seconds
Time After: 0.05096 seconds
Time Taken: 0.00612 seconds
Memory After: 2,261.836 KB
Time Before: 0.07656 seconds
Time After: 0.07671 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 2.30855 seconds
Time After: 2.31063 seconds
Time Taken: 0.00208 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 2.31710 seconds
Time After: 2.31726 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 2.31957 seconds
Time After: 2.32133 seconds
Time Taken: 0.00176 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788880053, location = '/forums/private.php?do=newpm&explain=1&u=35637' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 2.34129 seconds
Time After: 2.34150 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
