Time Before: 0.01699 seconds
Time After: 0.02387 seconds
Time Taken: 0.00688 seconds
Time Before: 0.02398 seconds
Time After: 0.02437 seconds
Time Before: 0.02465 seconds
Time After: 0.02478 seconds
Time Before: 0.02558 seconds
Time After: 0.02782 seconds
Time Taken: 0.00223 seconds
Time Before: 0.02484 seconds
Time After: 0.03237 seconds
Time Taken: 0.00753 seconds
Time Before: 0.03708 seconds
Time After: 0.03727 seconds
Time Before: 0.04000 seconds
Time After: 0.04119 seconds
Time Before: 0.03634 seconds
Time After: 0.04138 seconds
Time Taken: 0.00504 seconds
Time Before: 0.06721 seconds
Time After: 0.06735 seconds
Time Before: 0.08687 seconds
Time After: 0.08808 seconds
Time Before: 0.10111 seconds
Time After: 0.10125 seconds
Time Before: 0.10403 seconds
Time After: 0.10546 seconds
UPDATE session SET lastactivity = 1785299159, location = '/forums/private.php?do=newpm&explain=1&u=35713', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12404 seconds
Time After: 0.12431 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
