Time Before: 0.00151 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00268 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00299 seconds
Time After: 0.00327 seconds
Time Before: 0.00408 seconds
Time After: 0.00725 seconds
Time Taken: 0.00318 seconds
Time Before: 0.00332 seconds
Time After: 0.01220 seconds
Time Taken: 0.00887 seconds
Time Before: 0.01457 seconds
Time After: 0.01498 seconds
Time Before: 0.01773 seconds
Time After: 0.01897 seconds
Time Before: 0.01361 seconds
Time After: 0.01924 seconds
Time Taken: 0.00563 seconds
Time Before: 0.02841 seconds
Time After: 0.02859 seconds
Time Before: 0.03263 seconds
Time After: 0.03389 seconds
End call of global.php: 0.036533832550049
Time Before: 0.03822 seconds
Time After: 0.03842 seconds
Time Before: 0.04116 seconds
Time After: 0.04302 seconds
Time Taken: 0.00186 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=35787'
Time Before: 0.06018 seconds
Time After: 0.06047 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.059252023696899 seconds with 9 queries, spending 0.0095639228820801 doing MySQL queries and 0.049688100814819 doing PHP things.
