Time Before: 0.00138 seconds
Time After: 0.00202 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00209 seconds
Time After: 0.00285 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00313 seconds
Time After: 0.00330 seconds
Time Before: 0.00396 seconds
Time After: 0.00693 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00335 seconds
Time After: 0.01033 seconds
Time Taken: 0.00698 seconds
Time Before: 0.01229 seconds
Time After: 0.01270 seconds
Time Before: 0.01502 seconds
Time After: 0.01629 seconds
Time Before: 0.01169 seconds
Time After: 0.01647 seconds
Time Taken: 0.00478 seconds
Time Before: 0.02146 seconds
Time After: 0.02165 seconds
Time Before: 0.02357 seconds
Time After: 0.02495 seconds
Time Taken: 0.00138 seconds
Time Before: 0.02783 seconds
Time After: 0.02799 seconds
Time Before: 0.02993 seconds
Time After: 0.03141 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=35914', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.04370 seconds
Time After: 0.04395 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
