Time Before: 0.00142 seconds
Time After: 0.00254 seconds
Time Taken: 0.00112 seconds
Time Before: 0.00261 seconds
Time After: 0.00305 seconds
Time Before: 0.00368 seconds
Time After: 0.00404 seconds
Time Before: 0.00489 seconds
Time After: 0.00772 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00409 seconds
Time After: 0.01117 seconds
Time Taken: 0.00708 seconds
Time Before: 0.01296 seconds
Time After: 0.01341 seconds
Time Before: 0.01599 seconds
Time After: 0.01748 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01236 seconds
Time After: 0.01766 seconds
Time Taken: 0.00531 seconds
Memory After: 2,261.719 KB
Time Before: 0.02379 seconds
Time After: 0.02393 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02702 seconds
Time After: 0.02825 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.03217 seconds
Time After: 0.03233 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03492 seconds
Time After: 0.03641 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=35919' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05161 seconds
Time After: 0.05198 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
