Time Before: 0.00160 seconds
Time After: 0.00217 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00226 seconds
Time After: 0.00268 seconds
Time Before: 0.00292 seconds
Time After: 0.00306 seconds
Time Before: 0.00385 seconds
Time After: 0.00593 seconds
Time Taken: 0.00207 seconds
Time Before: 0.00313 seconds
Time After: 0.01058 seconds
Time Taken: 0.00745 seconds
Time Before: 0.01248 seconds
Time After: 0.01290 seconds
Time Before: 0.01536 seconds
Time After: 0.01658 seconds
Time Before: 0.01181 seconds
Time After: 0.01676 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02204 seconds
Time After: 0.02224 seconds
Time Before: 0.02439 seconds
Time After: 0.02562 seconds
End call of global.php: 0.027202844619751
Time Before: 0.02852 seconds
Time After: 0.02872 seconds
Time Before: 0.03063 seconds
Time After: 0.03209 seconds
SET lastactivity = 1785412716, location = '/forums/private.php?do=newpm&explain=1&u=35953'
Time Before: 0.04457 seconds
Time After: 0.04491 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.043686866760254 seconds with 9 queries, spending 0.0077009201049805 doing MySQL queries and 0.035985946655273 doing PHP things.
