Time Before: 0.01638 seconds
Time After: 0.02113 seconds
Time Taken: 0.00475 seconds
Time Before: 0.02125 seconds
Time After: 0.02162 seconds
Time Before: 0.02183 seconds
Time After: 0.02195 seconds
Time Before: 0.02268 seconds
Time After: 0.02511 seconds
Time Taken: 0.00243 seconds
Time Before: 0.02200 seconds
Time After: 0.02962 seconds
Time Taken: 0.00761 seconds
Time Before: 0.03540 seconds
Time After: 0.03562 seconds
Time Before: 0.03840 seconds
Time After: 0.03966 seconds
Time Before: 0.03463 seconds
Time After: 0.03989 seconds
Time Taken: 0.00525 seconds
Time Before: 0.06192 seconds
Time After: 0.06206 seconds
Time Before: 0.20992 seconds
Time After: 0.21116 seconds
End call of global.php: 0.21396613121033
Time Before: 0.22097 seconds
Time After: 0.22115 seconds
Time Before: 0.22427 seconds
Time After: 0.22602 seconds
Time Taken: 0.00175 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=35967', badlocation = 1
Time Before: 0.24667 seconds
Time After: 0.24693 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.24545502662659 seconds with 9 queries, spending 0.0079712867736816 doing MySQL queries and 0.23748373985291 doing PHP things.
