Time Before: 0.00512 seconds
Time After: 0.00817 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00825 seconds
Time After: 0.00883 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00914 seconds
Time After: 0.00926 seconds
Time Before: 0.01007 seconds
Time After: 0.01308 seconds
Time Taken: 0.00301 seconds
Time Before: 0.00933 seconds
Time After: 0.01746 seconds
Time Taken: 0.00813 seconds
Time Before: 0.02279 seconds
Time After: 0.02324 seconds
Time Before: 0.02557 seconds
Time After: 0.02679 seconds
Time Before: 0.02208 seconds
Time After: 0.02699 seconds
Time Taken: 0.00492 seconds
Time Before: 0.04545 seconds
Time After: 0.04560 seconds
Time Before: 0.05567 seconds
Time After: 0.05696 seconds
End call of global.php: 0.058963060379028
Time Before: 0.06222 seconds
Time After: 0.06243 seconds
Time Before: 0.06513 seconds
Time After: 0.06659 seconds
SET lastactivity = 1776966809, location = '/forums/private.php?do=newpm&explain=1&u=36018'
WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.08430 seconds
Time After: 0.08457 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.083199977874756 seconds with 9 queries, spending 0.0087695121765137 doing MySQL queries and 0.074430465698242 doing PHP things.
