Time Before: 0.00138 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00231 seconds
Time Before: 0.00252 seconds
Time After: 0.00262 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00331 seconds
Time After: 0.00601 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00267 seconds
Time After: 0.00944 seconds
Time Taken: 0.00677 seconds
Time Before: 0.01152 seconds
Time After: 0.01195 seconds
Time Before: 0.01461 seconds
Time After: 0.01599 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01087 seconds
Time After: 0.01616 seconds
Time Taken: 0.00529 seconds
Memory After: 2,261.719 KB
Time Before: 0.02134 seconds
Time After: 0.02153 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02330 seconds
Time After: 0.02454 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.02783 seconds
Time After: 0.02801 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03027 seconds
Time After: 0.03181 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=36045' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04674 seconds
Time After: 0.04717 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
