Time Before: 0.01037 seconds
Time After: 0.01373 seconds
Time Taken: 0.00336 seconds
Time Before: 0.01381 seconds
Time After: 0.01420 seconds
Time Before: 0.01444 seconds
Time After: 0.01461 seconds
Time Before: 0.01600 seconds
Time After: 0.01820 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01466 seconds
Time After: 0.02227 seconds
Time Taken: 0.00761 seconds
Time Before: 0.02748 seconds
Time After: 0.02793 seconds
Time Before: 0.03064 seconds
Time After: 0.03180 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02671 seconds
Time After: 0.03200 seconds
Time Taken: 0.00529 seconds
Time Before: 0.05465 seconds
Time After: 0.05481 seconds
Time Before: 0.06807 seconds
Time After: 0.06933 seconds
End call of global.php: 0.071823835372925
Time Before: 0.07642 seconds
Time After: 0.07669 seconds
Time Before: 0.07900 seconds
Time After: 0.08114 seconds
Time Taken: 0.00214 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=36076', badlocation = 1
Time Before: 0.10003 seconds
Time After: 0.10029 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.098940849304199 seconds with 9 queries, spending 0.0084540843963623 doing MySQL queries and 0.090486764907837 doing PHP things.
