Time Before: 0.00962 seconds
Time After: 0.01277 seconds
Time Taken: 0.00316 seconds
Time Before: 0.01285 seconds
Time After: 0.01334 seconds
Time Before: 0.01355 seconds
Time After: 0.01369 seconds
Time Before: 0.01462 seconds
Time After: 0.01687 seconds
Time Taken: 0.00224 seconds
Time Before: 0.01379 seconds
Time After: 0.02159 seconds
Time Taken: 0.00780 seconds
Time Before: 0.02632 seconds
Time After: 0.02673 seconds
Time Before: 0.02982 seconds
Time After: 0.03131 seconds
Time Before: 0.02556 seconds
Time After: 0.03156 seconds
Time Taken: 0.00601 seconds
Time Before: 0.04917 seconds
Time After: 0.04930 seconds
Time Before: 0.05824 seconds
Time After: 0.05979 seconds
Time Taken: 0.00155 seconds
End call of global.php: 0.062016010284424
Time Before: 0.06652 seconds
Time After: 0.06669 seconds
Time Before: 0.06984 seconds
Time After: 0.07133 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=36140'
Time Before: 0.08629 seconds
Time After: 0.08657 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
Page generated in 0.085285902023315 seconds with 9 queries, spending 0.0083889961242676 doing MySQL queries and 0.076896905899048 doing PHP things.
