Time Before: 0.02303 seconds
Time After: 0.02928 seconds
Time Taken: 0.00625 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02939 seconds
Time After: 0.02980 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03010 seconds
Time After: 0.03023 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03110 seconds
Time After: 0.03354 seconds
Time Taken: 0.00243 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03030 seconds
Time After: 0.03929 seconds
Time Taken: 0.00899 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04602 seconds
Time After: 0.04644 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04786 seconds
Time After: 0.04915 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04524 seconds
Time After: 0.04938 seconds
Time Taken: 0.00414 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.09529 seconds
Time After: 0.09546 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.16844 seconds
Time After: 0.16967 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.17247080802917
Time Before: 0.20436 seconds
Time After: 0.20456 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.21390 seconds
Time After: 0.21572 seconds
Time Taken: 0.00182 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772844554, location = '/forums/private.php?do=newpm&explain=1&u=36224'
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.24496 seconds
Time After: 0.24523 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.24389600753784 seconds with 9 queries, spending 0.0083653926849365 doing MySQL queries and 0.23553061485291 doing PHP things.
