Time Before: 0.00138 seconds
Time After: 0.00184 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00191 seconds
Time After: 0.00242 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00263 seconds
Time After: 0.00274 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00348 seconds
Time After: 0.00601 seconds
Time Taken: 0.00253 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00279 seconds
Time After: 0.00941 seconds
Time Taken: 0.00662 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01132 seconds
Time After: 0.01173 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01477 seconds
Time After: 0.01715 seconds
Time Taken: 0.00238 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01070 seconds
Time After: 0.01732 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02252 seconds
Time After: 0.02264 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02449 seconds
Time After: 0.02571 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.027317047119141
Time Before: 0.02868 seconds
Time After: 0.02882 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03085 seconds
Time After: 0.03226 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=36404'
Time Before: 0.04474 seconds
Time After: 0.04505 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.043898105621338 seconds with 9 queries, spending 0.0091555118560791 doing MySQL queries and 0.034742593765259 doing PHP things.
