Time Before: 0.00133 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00231 seconds
Time Before: 0.00251 seconds
Time After: 0.00266 seconds
Time Before: 0.00328 seconds
Time After: 0.00594 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00271 seconds
Time After: 0.01034 seconds
Time Taken: 0.00763 seconds
Time Before: 0.01270 seconds
Time After: 0.01308 seconds
Time Before: 0.01550 seconds
Time After: 0.01674 seconds
Time Before: 0.01213 seconds
Time After: 0.01690 seconds
Time Taken: 0.00478 seconds
Time Before: 0.02234 seconds
Time After: 0.02251 seconds
Time Before: 0.02452 seconds
Time After: 0.02576 seconds
Time Before: 0.02973 seconds
Time After: 0.02990 seconds
Time Before: 0.03298 seconds
Time After: 0.03442 seconds
UPDATE session SET lastactivity = 1784748523, location = '/forums/private.php?do=newpm&explain=1&u=36429' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.05280 seconds
Time After: 0.05310 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
