Time Before: 0.01013 seconds
Time After: 0.01578 seconds
Time Taken: 0.00565 seconds
Time Before: 0.01586 seconds
Time After: 0.01625 seconds
Time Before: 0.01649 seconds
Time After: 0.01665 seconds
Time Before: 0.01742 seconds
Time After: 0.01990 seconds
Time Taken: 0.00248 seconds
Time Before: 0.01671 seconds
Time After: 0.02402 seconds
Time Taken: 0.00731 seconds
Time Before: 0.02939 seconds
Time After: 0.02977 seconds
Time Before: 0.03227 seconds
Time After: 0.03351 seconds
Time Before: 0.02874 seconds
Time After: 0.03369 seconds
Time Taken: 0.00495 seconds
Time Before: 0.05375 seconds
Time After: 0.05387 seconds
Time Before: 0.06351 seconds
Time After: 0.06476 seconds
End call of global.php: 0.066831111907959
Time Before: 0.07060 seconds
Time After: 0.07074 seconds
Time Before: 0.07322 seconds
Time After: 0.07465 seconds
SET lastactivity = 1783091324, location = '/forums/private.php?do=newpm&explain=1&u=36544', badlocation = 1
Time Before: 0.09284 seconds
Time After: 0.09310 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.091819047927856 seconds with 9 queries, spending 0.0078611373901367 doing MySQL queries and 0.08395791053772 doing PHP things.
