Time Before: 0.00551 seconds
Time After: 0.00799 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00807 seconds
Time After: 0.00896 seconds
Time Taken: 0.00089 seconds
Time Before: 0.00918 seconds
Time After: 0.00931 seconds
Time Before: 0.01016 seconds
Time After: 0.01263 seconds
Time Before: 0.00937 seconds
Time After: 0.01716 seconds
Time Taken: 0.00779 seconds
Time Before: 0.02090 seconds
Time After: 0.02125 seconds
Time Before: 0.02370 seconds
Time After: 0.02492 seconds
Time Before: 0.02000 seconds
Time After: 0.02514 seconds
Time Taken: 0.00514 seconds
Time Before: 0.03639 seconds
Time After: 0.03658 seconds
Time Before: 0.04568 seconds
Time After: 0.04693 seconds
End call of global.php: 0.049197912216187
Time Before: 0.05238 seconds
Time After: 0.05258 seconds
Time Before: 0.05495 seconds
Time After: 0.05639 seconds
SET lastactivity = 1789052608, location = '/forums/private.php?do=newpm&explain=1&u=36547'
Time Before: 0.07689 seconds
Time After: 0.07717 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.075881004333496 seconds with 9 queries, spending 0.008425235748291 doing MySQL queries and 0.067455768585205 doing PHP things.
