Time Before: 0.02844 seconds
Time After: 0.03531 seconds
Time Taken: 0.00687 seconds
Time Before: 0.03539 seconds
Time After: 0.03586 seconds
Time Before: 0.03606 seconds
Time After: 0.03618 seconds
Time Before: 0.03700 seconds
Time After: 0.03889 seconds
Time Taken: 0.00189 seconds
Time Before: 0.03623 seconds
Time After: 0.04309 seconds
Time Before: 0.05449 seconds
Time After: 0.05486 seconds
Time Before: 0.05763 seconds
Time After: 0.05884 seconds
Time Before: 0.05386 seconds
Time After: 0.05905 seconds
Time Taken: 0.00518 seconds
Time Before: 0.10651 seconds
Time After: 0.10666 seconds
Time Before: 0.12853 seconds
Time After: 0.12980 seconds
Time Before: 0.14204 seconds
Time After: 0.14219 seconds
Time Before: 0.14496 seconds
Time After: 0.14711 seconds
Time Taken: 0.00216 seconds
UPDATE session SET lastactivity = 1776605792, location = '/forums/private.php?do=newpm&explain=1&u=36548' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.16687 seconds
Time After: 0.16722 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
