Time Before: 0.02527 seconds
Time After: 0.03415 seconds
Time Taken: 0.00889 seconds
Time Before: 0.03427 seconds
Time After: 0.03468 seconds
Time Before: 0.03492 seconds
Time After: 0.03505 seconds
Time Before: 0.03576 seconds
Time After: 0.03827 seconds
Time Taken: 0.00251 seconds
Time Before: 0.03510 seconds
Time After: 0.04296 seconds
Time Taken: 0.00786 seconds
Time Before: 0.05219 seconds
Time After: 0.05261 seconds
Time Before: 0.05516 seconds
Time After: 0.05637 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05152 seconds
Time After: 0.05662 seconds
Time Taken: 0.00510 seconds
Memory After: 2,261.719 KB
Time Before: 0.08493 seconds
Time After: 0.08505 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.10158 seconds
Time After: 0.10279 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.11666 seconds
Time After: 0.11697 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12029 seconds
Time After: 0.12172 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=36549', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.13886 seconds
Time After: 0.13918 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
