Time Before: 0.00153 seconds
Time After: 0.00211 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00218 seconds
Time After: 0.00258 seconds
Time Before: 0.00280 seconds
Time After: 0.00299 seconds
Time Before: 0.00364 seconds
Time After: 0.00600 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00304 seconds
Time After: 0.01018 seconds
Time Taken: 0.00714 seconds
Time Before: 0.01199 seconds
Time After: 0.01239 seconds
Time Before: 0.01364 seconds
Time After: 0.01484 seconds
Time Before: 0.01138 seconds
Time After: 0.01503 seconds
Time Taken: 0.00365 seconds
Time Before: 0.02140 seconds
Time After: 0.02160 seconds
Time Before: 0.02356 seconds
Time After: 0.02481 seconds
End call of global.php: 0.026795864105225
Time Before: 0.02804 seconds
Time After: 0.02817 seconds
Time Before: 0.03011 seconds
Time After: 0.03154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=36550', badlocation = 1
Time Before: 0.04605 seconds
Time After: 0.04635 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.044854879379272 seconds with 9 queries, spending 0.0078508853912354 doing MySQL queries and 0.037003993988037 doing PHP things.
