Time Before: 0.01094 seconds
Time After: 0.01614 seconds
Time Taken: 0.00521 seconds
Time Before: 0.01622 seconds
Time After: 0.01680 seconds
Time Taken: 0.00057 seconds
Time Before: 0.01706 seconds
Time After: 0.01720 seconds
Time Before: 0.01797 seconds
Time After: 0.02032 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01727 seconds
Time After: 0.02578 seconds
Time Taken: 0.00851 seconds
Time Before: 0.03440 seconds
Time After: 0.03485 seconds
Time Before: 0.03740 seconds
Time After: 0.03885 seconds
Time Before: 0.03373 seconds
Time After: 0.03909 seconds
Time Taken: 0.00536 seconds
Time Before: 0.06321 seconds
Time After: 0.06337 seconds
Time Before: 0.07831 seconds
Time After: 0.07954 seconds
End call of global.php: 0.081550121307373
Time Before: 0.09495 seconds
Time After: 0.09512 seconds
Time Before: 0.09808 seconds
Time After: 0.09952 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=36665'
Time Before: 0.11739 seconds
Time After: 0.11765 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.11619305610657 seconds with 9 queries, spending 0.0082216262817383 doing MySQL queries and 0.10797142982483 doing PHP things.
