Time Before: 0.00137 seconds
Time After: 0.00184 seconds
Time Before: 0.00191 seconds
Time After: 0.00238 seconds
Time Before: 0.00259 seconds
Time After: 0.00276 seconds
Time Before: 0.00353 seconds
Time After: 0.00601 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00280 seconds
Time After: 0.00985 seconds
Time Taken: 0.00705 seconds
Time Before: 0.01170 seconds
Time After: 0.01215 seconds
Time Before: 0.01444 seconds
Time After: 0.01561 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01115 seconds
Time After: 0.01585 seconds
Time Taken: 0.00470 seconds
Time Before: 0.02077 seconds
Time After: 0.02088 seconds
Time Before: 0.02255 seconds
Time After: 0.02379 seconds
End call of global.php: 0.025423049926758
Time Before: 0.02666 seconds
Time After: 0.02685 seconds
Time Before: 0.02883 seconds
Time After: 0.03031 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=36690', badlocation = 1
Time Before: 0.04255 seconds
Time After: 0.04292 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.041631937026978 seconds with 9 queries, spending 0.0081441402435303 doing MySQL queries and 0.033487796783447 doing PHP things.
