Time Before: 0.00307 seconds
Time After: 0.00383 seconds
Time Taken: 0.00076 seconds
Time Before: 0.00394 seconds
Time After: 0.00435 seconds
Time Before: 0.00460 seconds
Time After: 0.00474 seconds
Time Before: 0.00563 seconds
Time After: 0.00789 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00482 seconds
Time After: 0.01259 seconds
Time Taken: 0.00778 seconds
Time Before: 0.01497 seconds
Time After: 0.01518 seconds
Time Before: 0.01854 seconds
Time After: 0.01979 seconds
Time Before: 0.01410 seconds
Time After: 0.02007 seconds
Time Taken: 0.00597 seconds
Time Before: 0.02773 seconds
Time After: 0.02787 seconds
Time Before: 0.03035 seconds
Time After: 0.03161 seconds
Time Before: 0.03535 seconds
Time After: 0.03552 seconds
Time Before: 0.03833 seconds
Time After: 0.03998 seconds
Time Taken: 0.00165 seconds
UPDATE session SET lastactivity = 1783029146, location = '/forums/private.php?do=newpm&explain=1&u=36778' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.05412 seconds
Time After: 0.05442 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
