Time Before: 0.02157 seconds
Time After: 0.02484 seconds
Time Taken: 0.00327 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02492 seconds
Time After: 0.02537 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02557 seconds
Time After: 0.02569 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02657 seconds
Time After: 0.02860 seconds
Time Taken: 0.00203 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02574 seconds
Time After: 0.03274 seconds
Time Taken: 0.00700 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03819 seconds
Time After: 0.03860 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04003 seconds
Time After: 0.04119 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03756 seconds
Time After: 0.04139 seconds
Time Taken: 0.00382 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.07338 seconds
Time After: 0.07354 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.13376 seconds
Time After: 0.13500 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.16401 seconds
Time After: 0.16415 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.16847 seconds
Time After: 0.16993 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=36837' WHERE sessionhash = '871bbf3ae3a85736be8b96ebbb04a530'
Time Before: 0.19716 seconds
Time After: 0.19744 seconds
Memory Before: 5,998.203 KB
Memory After: 5,998.445 KB
