Time Before: 0.00768 seconds
Time After: 0.00986 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00996 seconds
Time After: 0.01067 seconds
Time Taken: 0.00071 seconds
Time Before: 0.01095 seconds
Time After: 0.01110 seconds
Time Before: 0.01183 seconds
Time After: 0.01441 seconds
Time Taken: 0.00257 seconds
Time Before: 0.01117 seconds
Time After: 0.02001 seconds
Time Taken: 0.00885 seconds
Time Before: 0.02477 seconds
Time After: 0.02500 seconds
Time Before: 0.02698 seconds
Time After: 0.02823 seconds
Time Before: 0.02396 seconds
Time After: 0.02848 seconds
Time Taken: 0.00452 seconds
Time Before: 0.04521 seconds
Time After: 0.04537 seconds
Time Before: 0.05370 seconds
Time After: 0.05496 seconds
Time Before: 0.06187 seconds
Time After: 0.06210 seconds
Time Before: 0.06466 seconds
Time After: 0.06611 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=36966', badlocation = 1 WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.08559 seconds
Time After: 0.08587 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
