Time Before: 0.00480 seconds
Time After: 0.00597 seconds
Time Taken: 0.00116 seconds
Time Before: 0.00607 seconds
Time After: 0.00644 seconds
Time Before: 0.00667 seconds
Time After: 0.00678 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00750 seconds
Time After: 0.01015 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00685 seconds
Time After: 0.01468 seconds
Time Taken: 0.00783 seconds
Time Before: 0.01732 seconds
Time After: 0.01770 seconds
Time Before: 0.01971 seconds
Time After: 0.02087 seconds
Time Before: 0.01656 seconds
Time After: 0.02113 seconds
Time Taken: 0.00456 seconds
Time Before: 0.03106 seconds
Time After: 0.03120 seconds
Time Before: 0.05229 seconds
Time After: 0.05350 seconds
Time Before: 0.05859 seconds
Time After: 0.05877 seconds
Time Before: 0.06166 seconds
Time After: 0.06315 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=37013', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.07609 seconds
Time After: 0.07656 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
