Time Before: 0.00168 seconds
Time After: 0.00239 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00245 seconds
Time After: 0.00340 seconds
Time Taken: 0.00094 seconds
Time Before: 0.00361 seconds
Time After: 0.00374 seconds
Time Before: 0.00440 seconds
Time After: 0.00701 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00379 seconds
Time After: 0.01145 seconds
Time Taken: 0.00766 seconds
Time Before: 0.01385 seconds
Time After: 0.01419 seconds
Time Before: 0.01549 seconds
Time After: 0.01674 seconds
Time Before: 0.01310 seconds
Time After: 0.01696 seconds
Time Taken: 0.00386 seconds
Time Before: 0.02196 seconds
Time After: 0.02208 seconds
Time Before: 0.02389 seconds
Time After: 0.02510 seconds
Time Before: 0.02788 seconds
Time After: 0.02811 seconds
Time Before: 0.03060 seconds
Time After: 0.03208 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=37023', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04863 seconds
Time After: 0.04885 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
