Time Before: 0.02939 seconds
Time After: 0.03915 seconds
Time Taken: 0.00976 seconds
Time Before: 0.03924 seconds
Time After: 0.03973 seconds
Time Before: 0.03996 seconds
Time After: 0.04013 seconds
Time Before: 0.04091 seconds
Time After: 0.04285 seconds
Time Taken: 0.00195 seconds
Time Before: 0.04019 seconds
Time After: 0.04688 seconds
Time Taken: 0.00669 seconds
Time Before: 0.05451 seconds
Time After: 0.05490 seconds
Time Before: 0.05763 seconds
Time After: 0.05886 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05387 seconds
Time After: 0.05909 seconds
Time Taken: 0.00522 seconds
Memory After: 2,261.719 KB
Time Before: 0.10535 seconds
Time After: 0.10555 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.12055 seconds
Time After: 0.12179 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.13136 seconds
Time After: 0.13157 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.13475 seconds
Time After: 0.13700 seconds
Time Taken: 0.00225 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=37054' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.15737 seconds
Time After: 0.15787 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
