Time Before: 0.00132 seconds
Time After: 0.00197 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00204 seconds
Time After: 0.00252 seconds
Time Before: 0.00270 seconds
Time After: 0.00285 seconds
Time Before: 0.00345 seconds
Time After: 0.00613 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00290 seconds
Time After: 0.00956 seconds
Time Taken: 0.00665 seconds
Time Before: 0.01127 seconds
Time After: 0.01163 seconds
Time Before: 0.01416 seconds
Time After: 0.01534 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01071 seconds
Time After: 0.01551 seconds
Time Taken: 0.00481 seconds
Time Before: 0.02180 seconds
Time After: 0.02195 seconds
Time Before: 0.02376 seconds
Time After: 0.02498 seconds
End call of global.php: 0.026657104492188
Time Before: 0.02783 seconds
Time After: 0.02798 seconds
Time Before: 0.03006 seconds
Time After: 0.03152 seconds
SET lastactivity = 1789055393, location = '/forums/private.php?do=newpm&explain=1&u=37088'
Time Before: 0.04832 seconds
Time After: 0.04858 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.047383069992065 seconds with 9 queries, spending 0.0080788135528564 doing MySQL queries and 0.039304256439209 doing PHP things.
