Time Before: 0.02331 seconds
Time After: 0.02774 seconds
Time Taken: 0.00443 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02785 seconds
Time After: 0.02844 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02867 seconds
Time After: 0.02894 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02965 seconds
Time After: 0.03190 seconds
Time Taken: 0.00224 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02899 seconds
Time After: 0.03749 seconds
Time Taken: 0.00850 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04429 seconds
Time After: 0.04483 seconds
Time Taken: 0.00054 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04751 seconds
Time After: 0.04872 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04362 seconds
Time After: 0.04891 seconds
Time Taken: 0.00528 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.07820 seconds
Time After: 0.07835 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.20916 seconds
Time After: 0.21045 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.21333193778992
Time Before: 0.24063 seconds
Time After: 0.24086 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.24582 seconds
Time After: 0.24729 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1773111211, location = '/forums/private.php?do=newpm&explain=1&u=37100', badlocation = 1
WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.27400 seconds
Time After: 0.27428 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
Page generated in 0.27255010604858 seconds with 9 queries, spending 0.008258581161499 doing MySQL queries and 0.26429152488708 doing PHP things.
