Time Before: 0.00161 seconds
Time After: 0.00213 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00220 seconds
Time After: 0.00269 seconds
Time Before: 0.00303 seconds
Time After: 0.00321 seconds
Time Before: 0.00413 seconds
Time After: 0.00699 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00330 seconds
Time After: 0.01088 seconds
Time Taken: 0.00758 seconds
Time Before: 0.01262 seconds
Time After: 0.01304 seconds
Time Before: 0.01544 seconds
Time After: 0.01676 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01206 seconds
Time After: 0.01693 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02175 seconds
Time After: 0.02189 seconds
Time Before: 0.02371 seconds
Time After: 0.02494 seconds
End call of global.php: 0.026525974273682
Time Before: 0.02792 seconds
Time After: 0.02811 seconds
Time Before: 0.03003 seconds
Time After: 0.03147 seconds
SET lastactivity = 1776568059, location = '/forums/private.php?do=newpm&explain=1&u=37106'
Time Before: 0.04369 seconds
Time After: 0.04402 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.042809963226318 seconds with 9 queries, spending 0.008608341217041 doing MySQL queries and 0.034201622009277 doing PHP things.
