Time Before: 0.01846 seconds
Time After: 0.02566 seconds
Time Taken: 0.00719 seconds
Time Before: 0.02578 seconds
Time After: 0.02644 seconds
Time Taken: 0.00066 seconds
Time Before: 0.02703 seconds
Time After: 0.02769 seconds
Time Before: 0.02851 seconds
Time After: 0.03050 seconds
Time Taken: 0.00199 seconds
Time Before: 0.02776 seconds
Time After: 0.03513 seconds
Time Taken: 0.00737 seconds
Time Before: 0.04158 seconds
Time After: 0.04200 seconds
Time Before: 0.04453 seconds
Time After: 0.04573 seconds
Time Before: 0.04078 seconds
Time After: 0.04599 seconds
Time Taken: 0.00521 seconds
Time Before: 0.06623 seconds
Time After: 0.06638 seconds
Time Before: 0.07690 seconds
Time After: 0.07820 seconds
End call of global.php: 0.080252170562744
Time Before: 0.08704 seconds
Time After: 0.08724 seconds
Time Before: 0.09004 seconds
Time After: 0.09153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=37216'
Time Before: 0.10775 seconds
Time After: 0.10811 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.10677599906921 seconds with 9 queries, spending 0.0084326267242432 doing MySQL queries and 0.098343372344971 doing PHP things.
