Time Before: 0.00390 seconds
Time After: 0.00440 seconds
Time Before: 0.00449 seconds
Time After: 0.00489 seconds
Time Before: 0.00507 seconds
Time After: 0.00517 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00585 seconds
Time After: 0.00806 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00522 seconds
Time After: 0.01146 seconds
Time Taken: 0.00624 seconds
Time Before: 0.01368 seconds
Time After: 0.01408 seconds
Time Before: 0.01666 seconds
Time After: 0.01795 seconds
Time Before: 0.01305 seconds
Time After: 0.01825 seconds
Time Taken: 0.00519 seconds
Time Before: 0.02883 seconds
Time After: 0.02907 seconds
Memory Before: 3,438.367 KB
Memory After: 3,438.883 KB
Time Before: 0.03121 seconds
Time After: 0.03247 seconds
End call of global.php: 0.034286975860596
Time Before: 0.03626 seconds
Time After: 0.03641 seconds
Time Before: 0.03940 seconds
Time After: 0.04085 seconds
SET lastactivity = 1772792632, location = '/forums/private.php?do=newpm&explain=1&u=373'
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.05611 seconds
Time After: 0.05661 seconds
Memory Before: 4,911.117 KB
Memory After: 4,911.336 KB
Page generated in 0.054639101028442 seconds with 9 queries, spending 0.0079965591430664 doing MySQL queries and 0.046642541885376 doing PHP things.
