Time Before: 0.03629 seconds
Time After: 0.04346 seconds
Time Taken: 0.00717 seconds
Time Before: 0.04354 seconds
Time After: 0.04395 seconds
Time Before: 0.04420 seconds
Time After: 0.04437 seconds
Time Before: 0.04519 seconds
Time After: 0.04824 seconds
Time Taken: 0.00305 seconds
Time Before: 0.04445 seconds
Time After: 0.05228 seconds
Time Taken: 0.00783 seconds
Time Before: 0.06042 seconds
Time After: 0.06083 seconds
Time Before: 0.06239 seconds
Time After: 0.06356 seconds
Time Taken: 0.00117 seconds
Time Before: 0.05972 seconds
Time After: 0.06374 seconds
Time Taken: 0.00402 seconds
Time Before: 0.09501 seconds
Time After: 0.09513 seconds
Time Before: 0.11111 seconds
Time After: 0.11239 seconds
End call of global.php: 0.11466693878174
Time Before: 0.12094 seconds
Time After: 0.12114 seconds
Time Before: 0.12354 seconds
Time After: 0.12496 seconds
SET lastactivity = 1782992174, location = '/forums/private.php?do=newpm&explain=1&u=37312', badlocation = 1
Time Before: 0.14305 seconds
Time After: 0.14346 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.14204692840576 seconds with 9 queries, spending 0.0086569786071777 doing MySQL queries and 0.13338994979858 doing PHP things.
