Time Before: 0.00146 seconds
Time After: 0.00204 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00215 seconds
Time After: 0.00271 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00299 seconds
Time After: 0.00318 seconds
Time Before: 0.00408 seconds
Time After: 0.00732 seconds
Time Taken: 0.00323 seconds
Time Before: 0.00326 seconds
Time After: 0.01195 seconds
Time Taken: 0.00869 seconds
Time Before: 0.01438 seconds
Time After: 0.01474 seconds
Time Before: 0.01732 seconds
Time After: 0.01872 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01372 seconds
Time After: 0.01897 seconds
Time Taken: 0.00525 seconds
Time Before: 0.02525 seconds
Time After: 0.02545 seconds
Time Before: 0.02774 seconds
Time After: 0.02908 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.030712127685547
Time Before: 0.03181 seconds
Time After: 0.03239 seconds
Time Before: 0.03432 seconds
Time After: 0.03581 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=37359', badlocation = 1
Time Before: 0.04916 seconds
Time After: 0.04952 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.048249959945679 seconds with 9 queries, spending 0.009702205657959 doing MySQL queries and 0.03854775428772 doing PHP things.
