Time Before: 0.01667 seconds
Time After: 0.02410 seconds
Time Taken: 0.00743 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02418 seconds
Time After: 0.02462 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02486 seconds
Time After: 0.02500 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02623 seconds
Time After: 0.02916 seconds
Time Taken: 0.00293 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02507 seconds
Time After: 0.03370 seconds
Time Taken: 0.00862 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04182 seconds
Time After: 0.04227 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04382 seconds
Time After: 0.04504 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04113 seconds
Time After: 0.04525 seconds
Time Taken: 0.00412 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.10176 seconds
Time After: 0.10199 seconds
Memory Before: 3,655.680 KB
Memory After: 3,656.195 KB
Time Before: 0.69890 seconds
Time After: 0.70109 seconds
Time Taken: 0.00219 seconds
Memory Before: 4,133.273 KB
Memory After: 4,133.867 KB
Time Before: 0.72292 seconds
Time After: 0.72307 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.72790 seconds
Time After: 0.72955 seconds
Time Taken: 0.00165 seconds
Memory Before: 5,481.203 KB
Memory After: 5,610.805 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=37463', badlocation = 1 WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.75260 seconds
Time After: 0.75291 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.969 KB
